June 29, 2003, 04:50 |
backgroup color when export graphics
Hi, all,
Is it possible to change the backgroug color from black to while when I export the fluent/gambit graphics? Black bg is good in compter screen but white bg is good for printer. I have been struggling a while with no success. |
June 29, 2003, 08:44 |
Re: backgroup color when export graphics
Hi!
When you make a hardcopy file click on reverse beckgound/forgroun option. regards mateus |
June 29, 2003, 16:47 |
Thanks, Mateus. That works with fluent. But with Gambit I don't have that option. Further suggestion please?
June 30, 2003, 04:42 |
there is a way to do it:
go to Edit menu ..in this select defaults, then it will open default setings for u in this list at the botton there is a variable: WINDOWS_BACKGROUND_COLOR modify it to white, it will change the background |
June 30, 2003, 04:43 |
i forgot to mention in defaults panel select 'graphic' pane, there this var is
July 1, 2003, 14:09 |
Thanks zxaar, I'll try this later. jx
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
[ANSYS Meshing] Export .msh file for fluent by script | Mostapha | ANSYS Meshing & Geometry | 1 | August 2, 2011 05:33 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Importing I-DEAS unv file | hbetb | FLUENT | 1 | August 10, 2001 13:22 |
