-   FLUENT (
-   -   converge problem (
Li Jingping July 7, 2003 23:10
converge problem
I encounter a very strange problem in my simulation. I made several models each of them are similar to the cylinder or tube. However, I found it is most difficult for FLUENT to converge for the most common cylinder,i.e. no bend, no curvature, just a cylinder with velocity inlet on one end and outflow on the other end. After 200 iterations for steady flow, it can only converge to 3*10^-4.
Because limited insight to the CFD, I am confused with it. Anybody can explain this phenomenon for me ?
thanks a lot.
Best, Li Jingping
mateus July 8, 2003 01:23
Re: converge problem
Jou must realize that value of residuals is not nesseserily a good indicator for convergence. It is possible that you have a good initial sollution (in noncurved cilinder flow, that is not so hard to do), that means residuals can not get any smaller. Also I think that 3*10^-4 is allready a good convergence criteria. try to monitor pressure or velocity on outlet, or at a certain point - you wiil get a converged solution when value doesnt change any more... It may be also wise to define outlet bc as pressure outlet - it ussually works better...
Li Jingping July 8, 2003 02:54
thanks a lot!
