Home > Forums > FLUENT
Gambit face mesh
Old   July 9, 2003, 12:27
Default Gambit face mesh
chanchala
Hi I'm modelling flow through pipes in 3D. I want to mesh (Gambit 2.0) 2 intersecting pipes that have different geometry. One is simple cylidrical pipe, the other with complex geometry. At the intersection between the two pipes I want to model the walls (actually flanges in practise) on both the pipes where the fluid will hit these walls.
Problem is, I import the complex pipe (IGES from Pro Engineer- everything comes out as virtual) and draw the cylidrical one. I draw faces to represent the flange walls and mesh these separately to the solids. The mesh on the solids (including the sorrounding wall)is exported fine into Fluent 6.1 but the flange wall is not. Is it because it's a face mesh?
If so, how to overcome this problem? Because the complex pipe is virtual I don't have many options either. Thanks.
Old   July 11, 2003, 08:38
Default Re: Gambit face mesh
emre
Hi, You could try STEP output from Pro-E which works much better than IGES when importing into Gambit. Gambit will most probably not switch to vitual geometry. Regards emre
Old   July 18, 2003, 06:37
chanchala
thanks! I tried STEP and it's fine now
Thread Tools
Trackbacks are On
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Gambit face link mesh, please help David FLUENT 3 December 8, 2006 08:27
Gambit: face mesh starts at edge, not boundary lr Chris Bailey FLUENT 0 December 5, 2005 14:50
