-   -   Orthotropic Matl Constant (http://www.cfd-online.com/Forums/fluent/31799-orthotropic-matl-constant.html)
scott July 9, 2003 18:21
Has anyone experianced either of these problems:
When coding in an orthotropic material property through the command line (or journal) I get an error object #f, and it does not ask me for any data. The only way to fix it is through the gui.
The other problem is when applying a heat generation from a udf throgh the command line or journal it does not stick (there is no profile listed). Again the only way to fix it is to go into the gui and manually select it, and when I fix it in the gui it puts the same error object #f in the command line.
Hope someone has an answer, Thanks Scott
