Orthotropic Matl Constant
Old   July 9, 2003, 18:21
Default Orthotropic Matl Constant
scott
Has anyone experianced either of these problems:
When coding in an orthotropic material property through the command line (or journal) I get an error object #f, and it does not ask me for any data. The only way to fix it is through the gui.
The other problem is when applying a heat generation from a udf throgh the command line or journal it does not stick (there is no profile listed). Again the only way to fix it is to go into the gui and manually select it, and when I fix it in the gui it puts the same error object #f in the command line.
Hope someone has an answer, Thanks Scott
Chemical properties that are used in Fluent kimej FLUENT 4 August 19, 2011 11:29
Constant Volume Combustion with reactingFoam Alish1984 OpenFOAM Running, Solving & CFD 2 May 8, 2011 08:51
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 11:15
