-   -   gambit and gturbo (http://www.cfd-online.com/Forums/fluent/31801-gambit-gturbo.html)
pitu July 10, 2003 03:44
gambit and gturbo
Hi there, im working with gambit 2.0. if i try to activate the turbo tool, it doesnt work. is gturbo already a part of gambit 2.0 or not? could someone help me? thanks a lot!
mateus July 10, 2003 04:03
Re: gambit and gturbo
HI!
Bad News....You have to pay extra for Gturbo:(
MATEUS
mukkarum July 12, 2003 13:08
hi i want to make geometry of francis turbine in gambit. i have gturbo also. what parameters i would required. thanks
Guess July 12, 2003 13:28
You need to write the blade, hub, shroud profiles in a specific format called TUR (*.tur) and import into GAMBIT. Please see the GAMBIT doc for the format of the file.
mukkarum July 12, 2003 13:37
Hi, In which software i have to write the profile, and what is the method to generate the pofile of hub, shroud, runner. i have geometry file of gamm Francis Turbine. GAMM Francis Turbine Test Case 8 is a Turbine whose geometry files and experimental data is available for researcher so that they can do Numerical analysis and can validate there results with experimental data. I have downloaded its geometry files from web http://lmhwww.epfl.ch/Research/EVA/Gamm.html but these files are in .imh format. I tried to open it in Gambit but failed. May you please guide me in which CAD Software I can open it and Mesh it, so that I can do simulation in Fluent? i will be vey thankful for your help bye
bdi December 21, 2011 09:18
GAMM Francis turbine
Originally Posted by mukkarum
;106970
I was trying to find on the web the GAMM Francis turbine geometry, but it is not online anymore. Could you send me the geometry of the GAMM (stay & guide vanes, hub & shroud curves, runner blade sections)?
Thanks,
ArslanOZCAN January 9, 2012 04:26
i need the geometry files too. How can i reach them.
