Help: run FLUENT bechmark
For my part-time work, I was required to run a FLUENT bechmark case in AMD Opteron (OS: Linux). I has received FLUNT input data like: xxx.dat, xxx.cas and xxx.txt. The case is urgent, and I have no experience on FLUENT before. Would you kindly tell me a simple way about how to the run FLUENT bechmark case ?
Thanks in advance. SC |
Re: Help: run FLUENT bechmark
Thanks for your consideration. The problem has been solved successfully.
Best regards, SC |
| All times are GMT -4. The time now is 23:01. |
