Help: Batch file for Parallel Processing ( 2CPU )
Old   July 14, 2003, 07:32
Default Help: Batch file for Parallel Processing ( 2CPU )
SC
Dear FLUENT users:
I can use FLUENT 6.1 in Opeteron with batch files as
fluent 3d -g -i inputfile > outputfile 2>&1
with input file as below
rc xxx.cas rd xxx.dat /solve/init/init it 1000 wd xxx.out exit yes
However, there are 2 CPU for our AMD Opteron computer, I guess that maybe only one CPU is used in above batch file, I am confused by reading online help, because it seems for MPI parallel. my question is : How to run parallel FLUENT 6.1 in batch file way for 2 CPU is one computer?
Thanks for your help in advance.
SC
P.S. the OS is Linux
Old   July 15, 2003, 21:34
Default Answer:Batch file for Parallel Processing ( 2CPU )
SC
I have found the answer as: fluent 3d -t2 -g -i inputfile > outputfile 2>&1
However, I encounter another difficulty: How to record the every CPU time for the parallel FLUENT?
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
