ISAT error and ddasac failure
I'm trying to use FLUENT v6.1 for some supersonic combustion research and am getting one of the following errors:
(1) Error: isat_table init: xscale must be positive: x=0.000000e+00 This error happens when using the EDC model w/ ISAT enabled. (2) Error: rmap2: ddasac failure. This happens at varying # of iterations when I use the EDC model w/ direct integration (w/o ISAT). Any suggestions on fixing the problem would be appreciated. Thanks. --Stephen |
Re: ISAT error and ddasac failure
Try to set the error tolerance lower (e.g. 1e-4 or lower) or use direct integration. If that doesn't work, most likely your case cannot be solved by the solver or it doesn't have a converged solution.
