fluent bench mark casting problem
Old   July 17, 2003, 02:35
Default fluent bench mark casting problem
prashanth
dear sir, i have been working on fluent6 on a bench mark casting problem solving for both flow and heat transfer.the inlet for the molten metal has been chosen as pressure inlet as the mass flow rate is not known.the gauge total pressure has been assigned 1042.6068pas(with respect to the operating pressure taken as the atm pressure). we are also facing reversed flow during iterations.we presume the problem is with the boundary conditions. please suggest the appropriate boundary conditions.
Continuous casting simulation problem luke.christ FLUENT 6 November 24, 2020 07:14
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
