ask help on valve flow simulation(3D modelling) |
July 18, 2003, 17:39 |
Hello, anybody can give me hints on a flow control valve simulation? I created a 3D modelling, a big up oil container and a small valve at bottom. Here are some boundary conditions defined: 1 unsteady laminar flow, under atmospheric pressure operation condition, only gravity causes the flow; 2 one phase fluid, because it will work on unpredictable temperature, so I set energy in.
Because I am a newer on FLUENT, so all the time I got rubbish results. So what should be correct settings? I did setting on Define-model,energy, viscous ; material; operation condition; boundary conditions; solver-controls; solution; initilize and iterate. Sometimes the iterate doesn't run or just appears one convergence, 0; sometimes the result on pressure is decreasing along the gravity direction. And where is the correct reference pressure location? Please tell me what shall I do on this modelling, I really need your kind help. |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 16:30 |
VOF modelling open channel river flow | Matthew Roberts | FLUENT | 6 | July 31, 2009 12:52 |
Turbulence modelling validation : Orifice flow | Joe | Main CFD Forum | 2 | July 26, 2006 16:41 |
modelling slug flow with pressure inlet | Azman | FLUENT | 0 | May 29, 2006 06:45 |
Compressible Flow Modelling? | yeo | FLUENT | 4 | March 7, 2003 07:08 |
