check grid failed
Old   July 30, 2003, 00:24
Default check grid failed
nikita
hello friends, i got a problem in running my 3d drawing since i got a warning msg when checking grid.For your info, the warning said that non-positive volume exist, but when i ignore the warning and proceed, i have a problem in iterate the case,The error is:divergence deteced in AMG solver:x-momentum.My 3 d drawing has 669543 mesh volume with 140792 node..pls advise..tq in advance
Old   July 30, 2003, 02:31
Default Re: check grid failed
Jürgen
Well, if you have cells with a negative volume, this means the cell is folded. You nedd to correct this error in the grid.
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
grid check failed yubaibai88 FLUENT 5 April 7, 2010 07:05
grid checked failed warning zubair FLUENT 5 March 1, 2009 02:55
Grid check fails after sliding mesh calculation Tito FLUENT 0 March 3, 2008 14:28
help! grid check error Gary Holland FLUENT 9 April 25, 2005 13:37
