About UDF??
Old   July 20, 2003, 04:24
Default About UDF??
ccc
hi, is there anyone who has encoutered strange problems when using UDF of Fluent6.18? It seems the UDFs sometimes works well, and however, sometimes they make nothings.
Old   July 22, 2003, 05:20
Default Re: About UDF??
sunny
Old   July 22, 2003, 20:18
ccc
sunny, I can not see your message.
Old   July 23, 2003, 11:21
emma chen
I have worked with UDF in fluent 6.1.15 and 6.1.18. Regarding to the interpreted UDF, it's simply to handle with it. As for compiled UDF, it's much more complicated. But if you would install the necessary compiler for the correspondent platform, built all the directories and copied the makefile and user-defined files, everything would be ok, unless your c source code has been somehow wrongly written.
I hope it's helpful to you!
Emma
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
