-   -   Static Pressures (http://www.cfd-online.com/Forums/fluent/31868-static-pressures.html)
Furness July 22, 2003 09:28
Static Pressures
Hi, I am modeling the air flow over a cavity, and comparing my data to experimental results, but I seem to be way off. My pressures are in the hundreds (-100Pa to upwards of 600Pa) but the experimental data shows a much smaller range of -10Pa to 150Pa or so. Typical air speeds at my Velocity Inlet BC range from 10ft/s to 100ft/s - which I convert to m/s. Air flow is viscous and the exit BC is Pressure outlet. Can anyone help me?
