Home > Forums > FLUENT
non-premixed combustion
Old   July 24, 2003, 14:32
Default non-premixed combustion
KE
I built a nonpremixed combustion model using Fluent, but the temperaure is very high (2850K) which is not I expected.
And how to include the Buoyancy effect into the simulation?
Your suggestions are welcomed!
Thanks
Old   July 25, 2003, 05:36
Default Re: non-premixed combustion
Erwin
If you're using a pdf model make sure it is non-adiabatic.
For buoyancy, click 'gravity' in the operating conditions panel and change z-parameter to -9.18 m/s2.
Old   July 25, 2003, 14:38
KE
Thank you for your suggestion. But in the menu, non-precmixed combustion could be modeled either by "pdf" or "species transport". This time I will try "pdf"to see the effect.
Thanks!
Old   July 28, 2003, 07:55
Erwin
If you used species transport, don't forget to include radiation to get rid of all that heat.
Thread Tools
Trackbacks are On
Modelling of premixed combustion in a burner rig ThomasS FLUENT 9 June 16, 2016 23:12
combustion model in premixed combustion chamber wuyu FLUENT 7 October 21, 2015 13:18
Non Premixed Combustion santhosh1987 FLUENT 2 April 10, 2013 04:24
Premixed Combustion IS FLUENT 3 July 9, 2010 20:22
Non-adiabatic Premixed combustion through scriptin Mahesh FLUENT 0 March 31, 2007 08:19
