August 4, 2003, 00:57 |
mole concentration of species (kmole/m3)
Can anyone tell me how the mole concentration of species (kmole/m3) is calculated in Fluent?
Why kmole is used not mole! In real life the concentration of pollutants are not high e.g. CO concentration in a car park should be less then 30 mg/m3). Have any one validated the concentration results against measurement data? Thanks for your time |
August 4, 2003, 06:04 |
Re: mole concentration of species (kmole/m3)
Hi Neihad, Fluent converts inside, and yes its true that its kmole/m3.
Because in MKS system, unit of pollutants is kmole and volume is m3. Cathy |
August 4, 2003, 11:09 |
I have posted about the subject earlier. It is true that fluent uses kmol/m3, which can be irritating. I have chosen to model concentration with a UDS and standard mass flow flux function. In this case you can use any units you care for.
August 5, 2003, 05:41 |
which version of the FLUENT you are using it??
i was been told that the calculation for the mole conecentration in Flunet V6.0 got some problems.... corretced in Fluent V6.1.18 take care |
August 5, 2003, 23:48 |
Thanks Cathy, Andrew and Ivan,
I am using Fluent 6.1.18. I think it will good to know how fluent is predicting the mole concentration at the pollutant source from the boundary conditions (e.g. mass fraction and inlet velocity). Therefore, we could compare our calculations and measurements with fluent methodology. Regards |
August 6, 2003, 01:55 |
Guys whats the hangup with units?????
You can always convert these from one to the other with little effort. If you want to see it differently on your screen I suggest you write a custom field function to multiply your results appropriately. If you want mass concentration to be reported instead of molar concentration just define a custom field fucntion as: C_mass_i = rho*Yi It will take less time to define than the time I've spent writing this email! Greg |
Display Modes | |
Species Partial Pressure or Mole Fraction | Priya | FLUENT | 2 | July 25, 2006 09:21 |
Species concentration loss | N | FLUENT | 0 | January 12, 2006 11:11 |
Species concentration at the flow exit | Kavitha | FLUENT | 5 | May 28, 2005 07:24 |
negative species concentration again | Andrew Garrard | FLUENT | 0 | March 22, 2005 11:36 |
Fidap 7.63: species Concentration | Lisa Eastep | Main CFD Forum | 4 | June 22, 1999 20:03 |
