interface error:poly triangulate!
Old   August 4, 2003, 04:22
Default interface error:poly triangulate!
l.j
i'm using dynamic mesh to simulate an unsteady problem.when i create interface zone,an error appears : Poly triangulate.What's that? How to solve the problem? Is there anybody can explain it in detail? Thanks a lot!
Old   August 6, 2003, 01:41
Default Re: interface error:poly triangulate!
h6h6
the two interfaces are not at same place.
If the two faces are in X-Y, those Z is not same!
You test the two faces!
This often occurs when the two face are real faces cutted.
Old   August 6, 2003, 02:09
lj
thanks, h6h6, l try it
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
