Home > Forums > FLUENT
floating point error
Old   August 6, 2003, 01:08
Default floating point error
nikita
hello friends, while iterating my 3d drawing, this error has appeared: floating point error.why???pls advise
Old   August 6, 2003, 04:26
Default Re: floating point error
vinod
hi Make sure that the route file or folder name doesnt have space. It should be single word. I think it will work just try this
vinod
Old   August 6, 2003, 11:24
nikita
dear vinod, i am not understand what do u mean by folder name should not have a space. for ur info:i write my file name as:nikita2.msh pls advise
Old   August 6, 2003, 13:56
ap
A floating point error is an error which happens during a floting point operation.
Nothing to do with the name of the folder where you save your mesh or case file.
Are there other messages after the "Floating point error" one? Something like "Invalid number" or similar I mean.
Hi
ap
Old   August 7, 2003, 06:48
nikita
floating point error:invalid number......what's the problem of this
Old   August 8, 2003, 09:22
ap
This error may depend on different reasons.
For example, I encountered it using the granular model, because I did a mistake giving a boundary condition on granular temperature.
I'd suggest to check all your case settings. If you use UDF, check the code for errors too.
Hi
ap
Old   August 8, 2003, 12:53
thomas
Dear nikita, In case you use a UDF you should check if the 3 letters 'nan' are mentionnioned which means 'not a number' that would mean you effectuate a division by zero at the beginning of your iterative process.
cheers tom
Old   August 9, 2003, 01:00
nikita
dear friends, it seems that this error comes when i start scaling grid.in gambit, all my dimension is in mm, when in fluent i convert it in meter using buttone SCALE.after it, when i iterate,about hundred iteration, this error appeared.but when i not scale my drawing to m...and let it be as in gambit..then the iteration is success..but the result is very very bad..pls advise
Old   August 16, 2003, 10:08
neu
don't close ur output window during iterating process
Thread Tools
Trackbacks are On
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
