-   -   heat transfer flux (http://www.cfd-online.com/Forums/fluent/31968-heat-transfer-flux.html)
Mark August 11, 2003 11:41
heat transfer flux
I have simulated a combustion gas flow in a furnace. The heat transfer rate report from the flux reports gives me a Negative value at the inlet indicating heat leaving the domain at the inlet and positive value at the outlet - indicating heat into the domain. This can't be right!!!
The only thing I think of, were there might be a problem is that I used an outlet profile from a previous simulation as the inlet boundary condition for this simulation. Could this be causing a problem?
Everything else looks fine.
Thanks for your help
Mark
Jin-Wook LEE August 11, 2003 20:55
Re: heat transfer flux
I guess that your combustion model is mixture-fraction/PDF model. Is it so ? Then it is possible. For example, let your fuel be CH4. Then, standard enthalpy of formation of fuel(CH4) and products(CO2 and H2O) are negative. Then, numerically, negative flux to the fuel inlet and positive flux at the outlet.
Sincerely, Jinwook
Mark August 12, 2003 04:18
Jinwook,
Thanks for your advice.
The combustion model I'm using is the eddy dissipiation. I should be using the PDF model but I wanted to used the eddy dissipiation model.
Is the advice the same for the eddy dissipiation model?
Regards,
Mark
Jin-Wook LEE August 13, 2003 01:42
YES...................
Negative or positive heat flux to the 'outlet' and/or to the 'inlet' is entirely dependent of the value of the 'standard state of enthalpy(let SSE)', not dependent of the combustion model.
For your reference, I would like to introduce my idea.
I am using my own SSE values, to avoid confusing and to easily check the heat balance. They are,
SSE of N2=0, O2=0, CO2=0, H2O=0....... SSE of fuel=LHV(positive value) SSE of CO=LHV(positive value) (for two step model).
Then you can avoid the confusing and you can get positve at the inlet and negative at the outlet. The above approach is NOT valid if you are considering backward reaction. Note that SSE is used to calculate the reaction rate of backward reaction.
SIncerely, Jinwook
Jin-Wook LEE August 13, 2003 01:49
Simply speaking, non-zero SSE for fuel only for single step model, and non-zero SSE for CO or other intermediate species for multi-step model.
