Home > Forums > FLUENT
Is there a limitation of memory size for UDFs?
Old   August 17, 2003, 08:51
Default Is there a limitation of memory size for UDFs?
Chen Fangzhi
I defined a UDF, which requires a large portion of memory. static int randn_1[100000] static int randn_2[100000] static int randn_2[100000]
Can I define three integer arraies like this? I think the needed memory size may be too large?
Old   August 18, 2003, 04:36
Default Re: Is there a limitation of memory size for UDFs?
kim
hi,
If this is a normal variable in C programming, you should refer to the stack size the C compiler permit. Anyway, such a large array definitaion will ocuppy a lot of memory. Why should you do like this?
Old   August 18, 2003, 04:42
Chen Fangzhi
I need a list of Gaussian random numbers. I don't want to generate them by my UDF scheme as it may spend long time. I use MatLab to create 100,000 random numbers and read them into memory.
I know this method is awful. FLUENT provides a macro "gauss_random()", but I don't how to use it.
Old   August 19, 2003, 02:46
Greg Perkins
For large arrays it makes more sense to allocate it on the heap by using a malloc or calloc call.
is do
real *mydata;
mydata = malloc(size_of_data);
mydata[0] = x
Greg
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
