Home > Forums > FLUENT
Non-Positive Volume
Old   August 18, 2003, 05:59
Default Non-Positive Volume
chetan
I have generated a model in proe for a Shell & a tube attached at bottom of shell (Simple Geometry)
Exported as solid in STEP & imported in GAMBIT, applied Grid & Boundary Conditions & exported a mesh for fluent 5/6
While reading in Fluent 6.1 & checking that grid, getting message as "there are non-positive volumes" & checking fails, still I am going for analisys and getting error as diverged solution
I am not able to understand the error, please help me out.
Also how to give grid in shell thickness?? or just to provide a surface as shell thickness??
Old   August 18, 2003, 17:07
Default Re: Non-Positive Volume
emre
Hi, When i see that error, i directly go back to Gambit and change the mesh, nothing to do in Fluent. regards emre
Old   August 19, 2003, 07:00
ap
Open the mesh in GAMBIT and check all volumes.
This will allow you to understand where the problem is.
GAMBIT will list all volumes which are not valid.
Hi
ap
Old   August 19, 2003, 07:42
chetan
How to check in Gambit for non valid volumes, can I create a volume for thickness for a tank model imported from PROE as STEP/SOLID?
Old   August 19, 2003, 14:59
ap
To check volumes in GAMBIT you have to enter the section to create 3D geometries (click on the cube in the Geometry bar), then right-click on the i icon, and select the Check function (with the V-like symbol).
Click on that button, select all volumes you want to check and click on Apply.
GAMBIT will list all valid and not valid volumes.
Hi
ap
Old   August 20, 2003, 12:01
nikita
the best solution for this..u do remeshing your drawing...there's some error on ur meshing never give up
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
