How can I set the inlet pressure?
Old   August 18, 2003, 15:52
Default How can I set the inlet pressure?
moon
For an incompressible flow, I use the velocity inlet and outflow condition. How can I set the inlet pressure(7bar)?
Old   August 18, 2003, 16:10
Default Re: How can I set the inlet pressure?
Jason
In Define --> Operation condition The pressure in boundary condition(if you defined) is based on this pressure, i.e. gauge pressure.
Old   August 18, 2003, 17:11
moon
default value is 1bar in operating pressure. I want to make the pressure 7bar or above is it possible without any treatments
Old   August 18, 2003, 18:02
Jason
sure you can change it directly. Bearing in mind that the pressure will change gas density and hence velocity if you are using mass_flow_inlet and defining material density as incompressible ideal gas.
Old   August 18, 2003, 19:08
moon
I define material density as incompressible ideal gas. when I set the operating pressure 7bar, density become 7times higher than that of 1bar. I just want to use air under the 7bar pressure. How can I make it?
Old   August 18, 2003, 19:21
moon
when I set the material, fluent questions whether overwrite the air or make new material. I made it new. is it wrong?
Old   August 19, 2003, 10:23
Rahul Hiwale
Hi Moon, If you need density of air at 1 bar then use constant density and give operating pressure as 7 bar. You can also use inlet pressure bc in that case use pressure as 7 bar + kinetic pressure (1/2.rho.v2) for incompressibale flow.
Fluent won't ask you to overwrite unless you change fluid/solid name. If you overwrite it will set that new mateial as default material instead of old material.
Rahul
Old   August 19, 2003, 14:17
moon
Thank you and Jason for your answer. If I have a problem with property variation(air) due to high heat flux and can't use constant density, what must I do? I use an incompressible ideal gas law for density and other properties as a function of temperature. all properties varies mainly with temperature. I use a segregated solver, not coupled. is it wrong?
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Setting dynamic pressure as the inlet BC ruined FLUENT 1 March 26, 2008 05:30
Pressure Boundary Problems Chris Siemens 2 June 21, 2005 08:20
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 01:47
Pressure inlet definitions Christian FLUENT 0 April 15, 2003 07:24
