Home > Forums > FLUENT
Achieving convergence in model with porouse medium
Old   August 19, 2003, 06:12
Default Achieving convergence in model with porouse medium
mneo
I have troubles with achieving convergence during computations what can I do? regards
Old   August 19, 2003, 06:56
Default Re: Achieving convergence in model with porouse me
ap
You can do many things to improve convergence. These are some general guidelines:
1) Use a good quality mesh.
2) If you're using a high order discretization scheme, try starting with the first order scheme, then switch to the higher one.
3) Reduce under-relaxation factors.
4) Change solver parameters (sweeps,...).
What model are you using? What discretization scheme? And what residuals don't reduce?
Hi
ap
Old   August 19, 2003, 07:14
mneo
I use: steady and k-e model first order scheme under-relaxation factors: preasure-0,2 momentum-0,5 k,e-0,6 mesh type-hexa
Old   August 20, 2003, 04:44
jieremy
And you can also conpute innitially using a simple Model.When u have got a initial value then u can change your model.I always do it and it works well.
Old   August 20, 2003, 05:19
mneo
My problem is flow through perforated plate with 45% open.I start computations without turning on "porous zone" and "laminar zone" in Fluid panel in boundary conditions and I achieved convergence. With turned on "laminar zone" I achieved convergence too but I dont't know it's right. Any suggestions? regards
Old   August 20, 2003, 07:36
ap
If the problem is the reduction of k-eps residuals, try to reduce their under-relaxation factors to 0.4.
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 27 February 7, 2016 12:58
Heat Transfer convergence Problem mit a 1/6 compressor model chili023 CFX 1 January 15, 2011 07:41
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
no convergence due to simplified model Jason FLUENT 0 September 9, 2008 23:03
Convergence of the porous medium model fpingqian FLUENT 0 January 8, 2008 23:54
