August 19, 2003, 12:19 |
grid fail
Hi all,
When I check my grid in fluent it tells me the grid is fine but when i smooth/swap the grid a non-positive volume warning comes up. I am using a mix of structured and unstructured cells. How I found this is, when I tried to adapt my grid using solution adaption - the non-positive volume warning comes up no matter what values i use. Can anyone give me advice on this matter? Thanx, Eric |
August 19, 2003, 21:41 |
Re: grid fail
hello eric, i used to be in your problem where the warning non-positive volume are always exist when i check grid, smooth and swap. After all, what i am doing is, i redo meshing the drawing again in Gambit, but this time, i change the meshing size. Pls make sure that your boundary condition is correct.this kind of thing, for the beginner is common.good luck
August 20, 2003, 04:45 |
Re: grid fail
u can remesh your grid especialy on the face uniting the structed grid and unstructed face.
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
grid check fail? | Adi | FLUENT | 1 | September 20, 2002 02:40 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
