Home > Forums > FLUENT
Is it possible in FLUENT
Old   August 19, 2003, 23:45
Default Is it possible in FLUENT
kumar
hi is it possible to determine boundary layer transition (from laminar to turbulent) along the length of a body in turbulent flow, using FLUENT or any other cfd codes, OR IS IT NOT POSSIBLE AT ALL
Old   August 20, 2003, 15:48
Default Re: Is it possible in FLUENT
Jonas Larsson
Some people will tell you that it is possible to predict transition with the two-equation models available in Fluent and other codes. However, this is only in theory and only in the special case of by-pass transition, ie transition caused by a very high free-stream turbulence level.
In practise most CFD codes with a two-equation eddy-viscosity model will give you turbulent boundary layers immediately and hence are not able to predict any transition. My advice is that you don't even try to predict transition just using a CFD code with a two-equation eddy-viscosity model.
The only reasonably reliable "industrial" way to predict transition is to use an ad-hoc transition model tuned for your specific application. Fluent does not have any such models.
Old   August 21, 2003, 00:48
kumar
Thank You Mr Larsson. This saves a lot of time and effort
Default Re: thanks
kumar
Thread Tools
Trackbacks are On
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 11 December 8, 2013 10:00
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
