August 21, 2003, 06:52 |
Virtual entities to real entities
Anybody know how to check the entities either real or virtual. Do you know how to change virtual entities to real entities?
August 21, 2003, 22:14 |
Re: Virtual entities to real entities
Under the ToolPad, Geometry-->edge/face/volume-->Query (right click on the i-button), enable the "display label", then choose your entities, if the label is volume.*, face.*, etc., the entity is real entity. If the label is v_volum.*, v_face.*, then is virtual entity. Hope I am right. So far I understand there is no command which can change the virtual entities directly to real entities.
August 22, 2003, 07:17 |
hi, in edges and face draw tool bars there is option in the toolbar to change from virtual to real entities next to information button good luck nabeel
Display Modes | |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 05:24 |
how to hook this udf | shanu | FLUENT | 1 | August 26, 2011 11:48 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 06:08 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 01:49 |
udf error | Rashmi | FLUENT | 0 | December 27, 2005 06:35 |
