August 14, 2003, 11:12 |
boundary conditions
Is it possible to use this set of boundary conditions in Fluent for 2D pipe flow:
Pressure inlet and constant mass flow rate? |
August 14, 2003, 12:41 |
Re: boundary conditions
For compressible flow: Total Pressure inlet & Static Pressure outlet
or Mass Flow Inlet & Static Pressure Outlet For incompressible flow: Velocity inlet & outlet condition |
August 15, 2003, 01:19 |
Hi!
I'm not shure what you want. Maybe you have the same problem as me...I have a known upstream pressure and velocity, but in Fluent you can't define both parameters on inlet bc. What I do is I define velocity inlet and pressure outlet (upstream pressure - pressure losses in pipe), and after simulation converges check if the pressure on inlet agrees with experimental one. It's a bit awkward solution but I think most of the people with this problem solve it this way... regards MATEUS |
August 15, 2003, 10:38 |
Thanks all. I am suprised that Fluent doesn't have a constant mass flowrate outlet boundary condition.
August 17, 2003, 04:58 |
I think the outlet boundary condition 'outflow' may help you for your problem and get constant mass flow rate. thomas
August 17, 2003, 20:54 |
constant mass flow rate is controled by approciate pressure. this may be the reason for no boundary conditions of constant mass flow rate in fluent software.
August 20, 2003, 05:23 |
Note that outflow boundaries cannot be used in the following cases:
if a problem includes pressure inlet boundaries; use pressure outlet boundary conditions (see Section 6.8) instead |
August 21, 2003, 13:31 |
For non critical flow, the mass flow rate is governed by both inlet and outlet pressures. To obtain a constant mass, it seems that I should use constant pressure inlet and try-and-error outlet pressure. Is this a correct way?
August 21, 2003, 20:24 |
#9 |
for the compressible flow,you can use these boundary condition:"Mass Flow Inlet & Static Pressure Outlet " then you have made the mass flow as a constant when you define the "Mass Flow Inlet".
August 24, 2003, 23:37 |
#10 |
To be clear, the conditions I have are: constant mass flow rate and constant inlet pressure. But I don't know the downstream pressure. The question was: How to set the boundary conditions?
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
