Home > Forums > FLUENT
help in fluent
Old   August 26, 2003, 04:50
Default help in fluent
xqz1997
I specify the boundary information :wall-container,wall-fiber1,wall-fiber2,wall-fiber3,wall-fiber4,and pressure-inlet.5;They are all changing in the fluent . wall-fiber1,wall-fiber1:015 wall-fiber2,wall-fiber2:014 wall-fbier3,wall-fiber3:013 wall-fiber4,wall-fiber4:012 pressure-inlet.5,pressure-inleet.5:001,pressure-inleet.5:007. why do they add so many walls?and how can I delete the surplus wall in fluent? please tell me the reason,Thank you very much.
Old   August 26, 2003, 05:35
Default Re: help in fluent
ap
I think FLUENT just splits your existing walls while reading the mesh you generated in GAMBIT.
Anyway, you don't have to delete anything to do your calculation.
Hi
ap
Old   August 26, 2003, 08:24
kim
If you defined two names of fluid in the gambit, fluent usually will split the boundary walls.
Thread Tools
Trackbacks are On
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 11 December 8, 2013 10:00
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
