September 3, 2003, 14:31 |
about the turbulent viscosity
Hello everyone, In fluent manual(6.2.2 Determining Turbulence Parameters)---Uniform Specification of Turbulence Quantities, "This is particularly true of external flows where unphysically large values of effective viscosity in the free stream can ``swamp'' the boundary layers. Does anybody know what the "SWAP THE BOUNDARY LAYERS" means? Thanks a lot.
Display Modes | |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet | Felipeb | Main CFD Forum | 1 | July 26, 2010 18:02 |
Turbulent viscosity and shear rate | shib | FLUENT | 0 | June 22, 2010 13:44 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 01:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
