Add New Material
Very strange! I follow the step of ug "creating a new material" and it just won't work. Can not be added into the list. Can anyone tell me why? Thanks.
DAVIS |
Re: Add New Material
To create a new material, go to Define->Materials...
Then 1) Insert the name of the new material. 2) Choose material type (fluid - solid) 3) Insert (optional) the chemical formula. 4) Define all properties of the new material. 5) Click on change-create. The new material will be added to the Solid Materials drop down list if you defined a solid material or to the Fluid Material drop down list if you defined a fluid material. Hi ap |
