Fire & Smoke in Building
I would like to simulate the development of fire(temperature distribution) and smoke in a building by using Fluent in order to validate the fire safety system. Unfortunately, I can't find any function in Fluent to simulate fire and smoke. Can anyone tell me if there is any function to do this in Fluent and what are they ?
It looks like I could simply put a (constant) heat source and (constant) smoke source without any chemical reaction to simulate fire (temperature distribution) and smoke, and treat them as passive scalars except I need to include the thermal stratification in the model. Could you please give me any suggestion or comment on this ? Thanks a million. Cheers |
Re: Fire & Smoke in Building
you can write UDFs which supply time-varying heat sources and time-varying species sources to represent the energy and smoke released from a fire.
Fire & Smoke simulation
Hi all,
Can anyone provide a tutorial for smoke and fire simulation using ANSYS Fluent? Please urgent reply |
Fire is combustion, Smoke is soot, CO2, ...
Fluent can model these so you can model Fire and Smoke using fluent. So easy. |
Thank u msaeedsadeghi, but i'm a new user of ANSYS fluent;
Is there any tutorials that can help? Regards |
See tutorials about combustion in these addresses.
https://www.sharcnet.ca/Software/Flu...g/main_pre.htm http://jullio.pe.kr/fluent6.1/help/html/tg/main_pre.htm http://202.118.250.111:8080/fluent/F...g/main_pre.htm http://cdlab2.fluid.tuwien.ac.at/LEH...g/main_pre.htm |
