Particle in a flow!
Old   September 21, 2003, 09:20
Default Particle in a flow!
varghese
Hi all!
I wish to simulate a particle carried by a flow in a tube. Which method in Fluent will be suitable for this problem. Dynamic mesh? Multiple Frame of References? Or any other method?
Thanks in advance.
Greetings Varghese
Old   September 22, 2003, 03:45
Default Re: Particle in a flow!
thomas
Hey, If it is question of a single particle yes the deforming mesh approach is the best. You will easily find this case example in the Fluent library. If it is question of several partcle I would suggest the langragian approach.
Hope this will help. thomas
Old   September 22, 2003, 03:49
varghese
It is a single particle. I wish to know how the particle flows with the fluid motion and how its own momentum drives it in different path as fluid stream-lines.
Where do we find the Fluent Library?
Greetings Varghese
Old   September 22, 2003, 06:39
thomas
Hey, You can probably find it on the fluent user website, certainly on validations or tutorial for dynamics/deforming mesh. If you cannot find it i would advice you to contact the fluent hotline of your country.
good luck, thomas
Old   September 30, 2003, 02:17
Alamgir
You could also have a look over Eulerian Multiphase Mixture flow. It is easy and best for both laminer and turbulence flow in pipe flow. I'm using that for 5 different particle for both steady and unsteady in a turbulent region.
Alamgir
Old   February 25, 2011, 15:32
Default Single particle motion with the flow
raj
sammyraj is on a distinguished road
Originally Posted by varghese
;108046
Hi all!
Thanks in advance.
Greetings Varghese
Hi Varghese,
I want to simulate single particle motion with the flow in tube.
This post looks old but I hope someone will reply. I am using Fluent 12.0 .
Can I use DPM model to do that or please guide me with best approach to this model.How can I do it with dynamic mesh?
Thank you in advance.
sammyraj is offline   Reply With Quote
Old   February 26, 2011, 07:51
Amir's Avatar
Amir
Amir is on a distinguished road
you can easily do that by DPM. it's not necessary to use dynamic mesh!!!
Amir is offline   Reply With Quote
Old   February 26, 2011, 15:36
raj
Thank for reply Amir.
I have a question again.
What should be value of the injection velocity when we try to define injection.???
Should it be same as flow velocity or anything else. As my partcile flows with the flow what velocity should I use for injection. B.C for the flow at the inlet (Continuous phase) is velocity inlet.
Thanks again!
Old   February 27, 2011, 10:56
Amir's Avatar
Amir
Hi raj,
it depends on your case, in realistic ones, fluid contains particles before entering the geometry in such cases you can set inlet flow velocity for injected particles. otherwise for particles with low stokes number, they can accommodate themselves in a relatively short time, here you can also use flow velocity.
if you set particle flow rate equal to 0, every streams contain just one particle otherwise your injection B.C. is the same for all particles in a same stream.
Old   March 11, 2011, 17:51
raj
Hello Amir,
Thank you again. I was able to run and track the particle.
I am trying to get the forces( mainly Drag)acting on the each particle. How can I get it from Fluent.
How can I define shape factor for cylinder with large aspect ratio.?
Old   March 12, 2011, 10:30
Amir's Avatar
Amir
Hi raj,
you can define a shape factor for your particles in:
define->models->discrete phase->tracking tab->drag parameters->non-spherical...
for finding drag force I don't know any straight forward procedure but you can use a simple UDF for that. if you find easier way, let me know.
regards,
Amir
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. STAR-CCM+ 2 October 11, 2011 10:19
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. CFX 2 September 15, 2011 15:30
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. FLUENT 0 September 14, 2011 15:40
particle tracking in unsteady flow peterchen FLUENT 1 July 22, 2010 22:18
