-   -   devergent solution (http://www.cfd-online.com/Forums/fluent/32187-devergent-solution.html)
nabeel mohsin September 23, 2003 05:52
devergent solution
hi, i have started coupled solver and implicit scheme.i set courant number 5.but the divergent solution is obtained.what should i do.i want to learn about turbulence model also.please any body can help me. nabeel
Guest September 23, 2003 10:14
Re: devergent solution
Start the iterations with courant number 1 or less with 1st order discretization scheme. Run it for 20 or 30 iterations and later you can increase the courant number slowly. Once you see the solution is stabilized, change the discretization scheme for "flow" to 2nd order and run it further.
nabeel mohsin September 24, 2003 06:58
i have attempted but the solution do not converge even after 3000 iterations. nabeel
ap September 25, 2003 07:06
Does your problem requires coupled solver (high speed aerodynamics or similar...)? If not, try to switch to the segregated solver, which usually is more stable.
Hi :)
ap
