dpm-stochastic particle tracking
Old   September 24, 2003, 01:37
Default dpm-stochastic particle tracking
Anna Blioebig
I'd like to use the stochastic particle tracking for turbulent dispersion of particles in a turbulent flow. I followed the instructions in the ug but in my case the "number of tries" option is always inactiv and not selectable. Can anybody tell me a reason for this? How can I be sure that the turbulent dispersion of particles will be included by FLUENT? What do I have to do that this option will be selectable?
Brief discription of my settings: Flow field: seg-solver, rsm-turbulence model, steady, 3d. After convergence of the flow field I introduced particles using the dpm-model dpm-setup: single injection, flow rate 0kg/s, dp=4e-6m, inert particles, stochastic model: random eddy life time - time constant 0.3.
Thanks for all helpfull replies
Anna
Old   September 24, 2003, 03:52
Default Re: dpm-stochastic particle tracking
Ben
Try a group injection not a single injection. Also why is your flow rate set to 0kg/s. This cannot be set to 0kg/s.
When using the DPM approach you inject in a particle stream (or streams). The stream is characterised by it's strength, which is determined by the number of particles within the stream that pass a point per second.
Old   September 24, 2003, 07:03
Anna Bliebig
I included your advices in my calculation but it didn't solve my problem so I returned to the old settings.
A 'group injection' is used if you want to set the defined initial conditions (d_p, T_p, x-, y-,z-coordinates..) between a certain range (see ug 19.9.2). Then FLUENT uses a linear variation between first and last value.
I use a mass flow rate of 0kg/s because for uncoupled calculations it isn't necessary to specify a value (see ug 19.9.5).
Over the several attempts to make the 'number of tries' check-box selectable I noticed that for me it isn't possible to use the cloud tracking model. But it is selcetable in the 'set multiple injections properties' panel - that seems funny to me. Are there any exlpanations for this?
Anna
Old   January 15, 2020, 02:32
hadis
hadisshojaei is on a distinguished road
Originally Posted by Anna Blioebig
;108082
Anna
Note that for unsteady particle tracking, the Number of Tries is set to 1 if using stochastic tracking. if you want active "Number of Tries", you set particle tracking steady.
hadisshojaei is offline   Reply With Quote
DPM particle tracking in stirred tank parisa- FLUENT 1 August 7, 2012 12:03
DPM particle tracking parisa- Main CFD Forum 2 June 15, 2011 05:12
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM tracking particle Clementine FLUENT 0 November 7, 2008 18:08
stochastic particle tracking Prachi Mehta FLUENT 0 March 26, 2004 09:00
