-   -   heat transfer with porous block in fluent (http://www.cfd-online.com/Forums/fluent/32195-heat-transfer-porous-block-fluent.html)
salhi September 24, 2003 06:21
Dear users, I want use Fluent to mdel heat transfer and fluid flow in channel containing a porous block (i.e.: channel partielly filled with a porous media). I can't sepcify the porous zone and particulary the interface fluid-porous region, I need your help
Chetan Kadakia September 25, 2003 04:43
Re: heat transfer with porous block in fluent
Why can't you specify a porous region? I believe that you can select the boundary condition of the surface to be a porous media. Look at tge b.c. panel, and see if it is an option. Tell me what you find.
