Pressure Inlet Conditions
Old   September 25, 2003, 02:55
Default Pressure Inlet Conditions
Sangeon
If I know the total pressure in inlet and this flow is supersonic, as they say, I need to specify the static pressure.
1) Why?
2) How can I get this static pressure? Just using isentropic relation and the given total pressure with Mach = 1?
Old   September 25, 2003, 04:18
Default Re: Pressure Inlet Conditions
Chetan Kadakia
You have to specify the static pressure in order to signify how much of the total pressure is dynamic pressure. You can estimate the dynamic pressure from the velocity, and then subtract the dynamic pressure from the total pressure and you have static pressure.
Po = Ps + Pd Po: Total Pressure Ps: Static Pressure Pd: Dynamic Pressure
Pd = 1/2(ro)V^2 ro: density V: velocity
Old   September 26, 2003, 05:42
Klarke_zhu
you can cancle the operation pressure,then input Gauge total pressure and the static pressure.Normally the static pressure can be set equal to the outpressre.You can see an example in the help files.
Pressure inlet boundary conditions for open channel flows jack2000 OpenFOAM Running, Solving & CFD 5 December 6, 2018 11:00
pressure with velocity inlet boundary conditions Ashraf Sharara FLUENT 1 August 21, 2008 07:29
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 01:47
Reversed flow in pressure inlet eric FLUENT 3 January 26, 2004 20:04
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
