-   -   Error about UDF (http://www.cfd-online.com/Forums/fluent/32216-error-about-udf.html)
zhou September 26, 2003 17:53
Error about UDF
I defined a constant density for mixture material by UDF as follow, but there are some errors information as following. Do you know what is problem? Thanks.
DEFINE_PROPERTY(cell_density,c,t) {
real den;
den=2967.7679;
return den; } cc: "den.c", line 4: error 1000: Unexpected symbol: "den". cc: "den.c", line 4: error 1588: "real" undefined. cc: "den.c", line 5: error 1588: "den" undefined. *** Error exit code 1
ap September 27, 2003 07:52
Re: Error about UDF
Just change the name of the variable den to something different, like "rho_mix", or easier, write the function as follow:
return(2967.7679);
From the error message, it seems that the internal compiler of FLUENT has some problem to manage the symbol you have choosen for the variable.
Hi :)
ap
