September 30, 2003, 10:19 |
two-step mechanism
I want to simulate methane/air combustion with the eddy dissipation model. But i want to use a two-step mechanism. I know where to input the reaction, i.e. materials/reaction/edit/total number of reactions. What i want to know is what values/reactions do i put in here? I really do not have any idea what to do. Can anyone help?? Thanks, Eric |
September 30, 2003, 11:41 |
Re: two-step mechanism
In the Materials panel, click on the Database button, and select the methane-air-2step mixture. Copy it to your mixtures' list and select it as your mixture. Now you're ready to use it in your eddy-dissipation model.
Regards, Ale |
September 30, 2003, 13:16 |
Thanks Ale,
The reason i want to use the two-step mechanism is to account for the intermediate species in the combustion. So that i get a more accurate temperature field and species concentrations in the results. Is this right? What is the advantage of using the two-step mechanism??? Thanks Eric |
September 30, 2003, 21:38 |
If you want to account for one intermediate species, e.g., CO, two step mechanism is enough. But if you want to account for many intermediate species, you should use mixture-fraction/PDF model.
Multi-step mechanism, of course, can increase the accuracy of the simulation. But more important one is more accurate reaction parameters, which are, in general, not universal constants, but mostly system dependent. Sincerely, Jinwook |
Display Modes | |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
