-   -   Question for Induction heat (http://www.cfd-online.com/Forums/fluent/32235-question-induction-heat.html)
J.W.Ryu October 1, 2003 00:01
Hello all,
I am considering heat and flow simulation including induction heat mechanism, such as Iron melting with high/low frequency induction heating. Does anybody have experience similar model to this? If yes, could you let me have your idea or method?
Thanks and regards,
J.W.Ryu
dr October 17, 2003 12:27
Re: Question for Induction heat
hi,
i suggest you go to the following adress: http://www.cranfield.ac.uk/cww/ccc/d...tg/node278.htm
this tutorial might help in your case
i hope this helps
dr
J.W.Ryu October 20, 2003 08:08
Dear Mr/Ms. Rochaya,
Thanks for your suggestion. But, I can not access adress that you suggested. Could you let me have correct adress?
Thanks and regards,
J.W.Ryu
dr October 20, 2003 10:07
hi,
you can find te same tutorial on this adress:
http://p2chpd-cluster.univ-lyon1.fr/...tg/node278.htm
I hope this helps
dr
J.W.Ryu October 23, 2003 08:22
Thanks for your advice. I have read this tutorial, and have tutorial book. What I want to know was the method to simjulate heat transfer from induction heat source. Probably my provious post made you confusion. I am sorry.
J.W.Ryu
