Home > Forums > FLUENT
Degassing BC in Fluent
Old   October 1, 2003, 19:24
Default Degassing BC in Fluent
Seb
Hi all,
With Fluent 6, I would like to know if it is possible to impose a degassing BC at an outlet as we do in CFX. In more details, for two-phase flows, an outlet where the dispersed phase (usually a gaz) can escape and the other fluid (the liquid) cannot.
Thanks.
Old   October 2, 2003, 04:06
Default Re: Degassing BC in Fluent
thomas
Hey, Ya man it can be done only by UDF using define profile. Then at the outlet you define a velocity inlet boundary condition and apply your UDF parameter. Can I know from what country are you from ?
regards thomas
Old   October 2, 2003, 08:10
Seb
Thanks Thomas,
I still have a problem with this procedure : the profil of the volume fraction and the velocity of the gas are unknown at the outlet. Hence, their profil cannot be defined.
I think I will have to expand the domain and add an "hold-up" of gaz. Hence, the outlet will be well defined. However, It will be more costly.
P.S. I am from Canada (Quebec)
Old   October 2, 2003, 08:52
thomas
Hey, Thanks to let me know where you are from, you name sounds like french so I wanted to figure out ... cause i am french. Okay you should explain to me a little bit more what you want to simulate ? are you trying to simulate bubble column or something like that ?
thomas
Old   October 2, 2003, 10:33
Seb
Hi Thomas,
Let say we have two rectangles (a small and a big one). The small rectangle is in the big one. THe domain is filled with water. The bubbles are produced underneath the small rectangle (inlet) and escape along its sides. The top of the big rectangle is the outlet. The remaining sides are walls. How do I manage to only let the bubbles escape from the top and not the liquid?
Thanks.
Old   October 2, 2003, 11:10
eric
hi, seb.
Fluent has recently launched a User Defined Functions (UDF) archive on Fluent's User Services Center (USC). a UDF for imposing a de-gassing boundary condition for the eulerian multiphase (euler/euler) & mixture models can be found there.
go to the USC (www.fluentusers.com), click on the UDF archive link, then choose "UDF examples". a brief desciption and source listing is provided.
good luck!
eric.
Old   October 2, 2003, 12:14
Seb
Thanks. All I need is to ask my boss to buy a C compiler.
Old   October 3, 2003, 04:01
thomas
hey, effectively get the udf from the fluent user web site is the best you can do. This udf will help you to realize what you want 'bubble escape when the liquid does not'. This UDF will set the water vertical velocity component at 0 -> to create a water recirculation, like that the water will not leave the domain. Then it is the contrary for the bubble, the gas horizontal velocity will be set at 0. The velocities value correspond to the value of the last cell before the outlet. The UDF you might get could be more complicate than what I explained (essentially because of free-surface geometry or repartition) but it consists in the same way.
hope this will hep you ! thomas
Thread Tools
Trackbacks are On
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 26 June 9, 2015 15:38
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
