multiple reactions
Old   October 3, 2003, 17:32
Default multiple reactions
siva
hi, is there any way i can use two different turbulence chemistry interactions for different reactions in fluent. i got two reactions in my reactor and i want to use laminar finite rate for one and eddy dissipation for other. thanks in advance. siva
Old   October 6, 2003, 00:08
Default Re: multiple reactions
Jin-Wook LEE
There might be several approach. The easiest way is :
You can do it by choosing combined model and by controlling reaction parameters.
For example, If you want to use eddy dissipation model, use reasonable eddy dissipation model parameters and very very small activation energy(or very very large pre-exponential constant). Then, chemical kinetics is very very fast, so that eddy dissipation model, which is slower reaction, can only be used. Vice versa.
Recall that slower reaction is used for combined model.
Sincerely, Jinwook
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
inconsistency in the chemical reactions in Reacting Foam? lfgmarc OpenFOAM Running, Solving & CFD 1 October 10, 2011 11:11
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
Duplicate/enhanced reactions in Chemkin? PattiMichelle Phoenics 0 March 2, 2002 17:19
