[Sponsors] | |||||
I want to adapt my grid in fluent using grid adaption using the temperature profile. My simulation is done with a first order scheme. My question is, should i converge the solution on a second order scheme before adapting the grid or is it ok to adapt from the first order solution?? Regards, Eric |
Usually the second order scheme gives more accurate results than the first order one, so also adaption should be better if based on a solution obtained with the 2nd order scheme.
I'd suggest, if possible (no unstable solution) and not too much time expensive, to obtain a converged solution with second order, then to adapt the grid, and let the solution converge again using second order discretization scheme. Hi ![]() ap |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| grid adaption mode NOT selectable via VNC | Ralf Schmidt | FLUENT | 2 | May 24, 2006 02:35 |
| Need help with Grid Adaption | _stephen_ | FLUENT | 0 | January 13, 2005 07:07 |
| Adaption by Y+ on a mixed grid with periodics | Martin Shanel | FLUENT | 0 | June 24, 2002 06:31 |
| Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 04:59 |
| Grid Adaption problems | Jie | FLUENT | 1 | February 26, 2002 11:03 |
