-   -   Gravity and combustion (http://www.cfd-online.com/Forums/fluent/32287-gravity-combustion.html)
eric October 8, 2003 13:05
Can anyone tell me where gravity is accounted for in the non-premixed combustion and species transport tutorials?
I can't see how the gravity is accounted for in these tutorials. Does this mean that gravity effects can be neglected in combustion type simulations?
Regards,
Eric
Jin-Wook LEE October 9, 2003 08:11
Re: Gravity and combustion
You can account for gravity by activating 'GRAVITY' in 'DEFINE->OPERATING-CONDITION', if you need.
In general, in large system(or high Re, or large flame...), gravity(buoyancy force effect) can be neglected. You can check it by Richardson number, Gr/Re^2. Re : Reynolds number, Gr : Grashof number.....
Sincerely, Jinwook
Colin October 9, 2003 17:27
You could refer your question to mine that posted by me: Gravity (g) Influence on Simulation Results
By the way, for the tunnel fire studies, I was convinced by Steve that even if the tunnel was horizontally placed, the gravity still play a role in your final results.
Jin-Wook LEE October 9, 2003 23:45
I agree with you for tunnel case.
For very large combustor, e.g., furnace of fossile power plant, the effect of gravity is fairl small. Anyway, gravity affects the results, negligible for somecase, fairly for certain cases, or sometimes very significantly.
Sincerely, Jinwook
eric October 10, 2003 04:11
Thanks for the reply.
What about a 1m long kiln of 0.5m diameter, Do you think gravity will have an effect on the flow in this case?
Also, I know that the gravity acts in the y direction in my model but do you apply the direction, i.e. -y, as well?
Thanks
Eric
Jin-Wook LEE October 12, 2003 21:43
Anybody can say that gravity affects the results. But nobody can say that gravity can be neglected, because it's dependent of the system which you are going to solve. Unfortunately, what I can say is, it should be decided by yourself. I recommend that you would compare two results with and without gravity for the first case.
Direction of gravity is dependent of your modeling(meshing). + or - is only the direction.
Sincerely, Jinwook
Narcis68 July 21, 2016 05:41
Originally Posted by Jin-Wook LEE
;108399
Sincerely, Jinwook
Hi
i am modelling a curved micromixer. and i'm not sure to account gravity or not.
i can not see gravity in the equations written in the paper.
but it seems without it the contours look different in comparison with those of paper's.
how should i explane the reason why i used gravity in this case?
can anybody help?
Thanks in advance
