Home > Forums > FLUENT
which c language is used in UDF
Old   October 9, 2003, 03:28
Default which c language is used in UDF
lingo
Hello. I never learn c language before.I find Turbo c ,c++ and visual c++ in our library.Can anyone tell me which c language is appropriate in user-defined function.Thanks a lot!
Old   October 9, 2003, 03:48
Default Re: which c language is used in UDF
calogero
Hello ! I think turbo C can make it ! but bear in mind that you'll be using variables (pointers ...etc) & macros that are proper (and most of the time IMPOSED) to FLUENT. so you won't go deep in C programming! bye
Old   October 9, 2003, 07:37
ap
Fluent uses the standard C language together with a set of macros which are specific of FLUENT, and defined in the header file "udf.h".
If you use interpreted UDF, you don't need any compiler, but you have some limitation in the language (see UDF manual for details).
If you need compiled UDF, on Windows platform, I'd suggest Microsoft Visual C++, because UDF Manual refers to it, and the makefile is written for that compiler.
Hi
ap
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
udf language + UDMI values chary FLUENT 0 October 5, 2007 06:58
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
