October 23, 2003, 03:41 |
moisture transfer through membrane
I am modeling a porous membrane heat exchanger which recover latent heat by transferring moisture from the hot & humid side to the cold side. I couldn`t find a way to model the moisture transfer through the membrane. Thank you very much for your help
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Coupled heat and moisture transfer in porous | Mike | FLUENT | 1 | May 4, 2004 12:05 |
mass transfer from fluids to membrane | Peter | FLUENT | 0 | August 2, 2002 14:27 |
