-   -   solid suspension in moving liquid (http://www.cfd-online.com/Forums/fluent/32371-solid-suspension-moving-liquid.html)
Jason October 23, 2003 11:19
I need to modeal a moving liquid area area with spherical solid particles inside. What kind of solver should I use? I tried setting particles as moving wall. But FLUENT prevented me from setting the velocity normal to the moving wall. Those particles have different velocity so I can't simply use relative velocity. Could you give me some suggestions?
Alamgir October 23, 2003 22:48
Re: solid suspension in moving liquid
Hi Jason,
I'm modelling same as you. I think better to use segregate solver with Multiphase mixture model that will allow you to impliment different velocities for every phases. Any help plz contact.
Alamgir
Jason October 27, 2003 11:50
What if those velocities of the particles are different even if they are not different phase? The velocities just depend on positions.
Ajay Rao October 27, 2003 15:55
A UDF be written specifying velocity/Rotation of the spherical particles .
Alamgir October 27, 2003 19:59
Just make it differet phases keeping all physical properties same.. then u can be able to introduce diff velocities.
Alamgir
