Compiled UDFs
Old   October 28, 2003, 15:49
Default Compiled UDFs
Devin
Hello everyone,
I'm having difficulty in using compiled udf's. I have the following error when using the nmake command:
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0 Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
makefile(51) : fatal error U1050: You need to define the environmental variable FLUENT_INC. Stop.
Has anyone seen this before and know how I can fix it? I'm using Microsoft Visual C++ 6.0 if that is of any help.
Thanks in advance, Devin
Old   October 28, 2003, 17:22
Default Re: Compiled UDFs
Leone
the problem is too wide. fatal error occur from many point in the program or Fluent.
Old   October 28, 2003, 19:17
Allan Walsh
Did you first run the C++ batch file to set environment variable (libraries, paths) - or set these yourself - prior to running nmake?
Old   October 28, 2003, 20:34
Devin
Thanks for the replies, I did actually run the patch with no luck. However, I was able to find what Environment Variables needed to be added and did so manually.
My new problem is that when linking the compiled udf to Fluent, an error occurs stating that the libudf.dll file could not be opened and file fl547s.exe could not be found. I search my harddrive for the file, but none exists.
Any thoughts?
Thanks, Devin
Old   October 28, 2003, 20:47
Alamgir
Ask your provider about that dll file, u can't detect it.
Alamgir
Interepreted Vs. Compiled UDFs Antonis Fluent UDF and Scheme Programming 10 March 22, 2018 11:15
Compiled UDFs - questions Antonis FLUENT 6 December 26, 2012 06:12
Using compiled UDF:s in different Fluent versions S H FLUENT 1 September 12, 2007 03:40
compiled udfs Ankit Somani FLUENT 1 October 19, 2006 14:24
accessing udf_library for compiled udf's Asghari FLUENT 0 August 9, 2006 04:41
