modelling of conjugate heat transfer problem
Old   October 27, 2003, 23:42
Default modelling of conjugate heat transfer problem
ajay chandra
How to put boundary conditions for conduction+convection problem because sovler picks only one medium but heat flow is through metal and metal to air? any body may please guide?
Old   October 28, 2003, 06:51
Default Re: modelling of conjugate heat transfer problem
Erwin
It is quite straightforward: in Gambit, define your metal grid similar as a fluid zone. In the fluid boundary conditions panel, set it to be a 'solid'.
After importing the mesh into Fluent, you can set the material type for this solid zone.
Parametric runs and Optimization in ANSYS (Conjugate Heat Transfer Problem) cp_jef ANSYS 0 May 30, 2011 04:08
Modelling the heat transfer during compression and cooling of natural gas pano Main CFD Forum 0 December 10, 2010 15:53
Heat transfer problem seojaho CFX 6 May 6, 2010 00:32
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
Heat Transfer Problem Help JB FLUENT 2 October 18, 2006 18:54
