about aluminium combustion,thank you
Old   November 2, 2003, 09:02
Default about aluminium combustion,thank you
cfdfans
I want to use fluent6 to simulate aluminium particle combustion. I use DPM model, but I woder which particle type I should use , Droplet or Combusting?
And does Combusting particle type only for coal combustion ?
thanks to you!!
Old   November 2, 2003, 15:09
Default Re: about aluminium combustion,thank you
cp
Hi
If you are considering any reaction, you need to select 'Combusting' particles. 'Droplet' will only deal with heating, evaporation, and boiling.
Combusting particles are not specific to coal. The approach is a generalized one for any surface type combustion. That should work for aluminum particles, provided you give appropriate properties.
Chendhil.
Old   November 3, 2003, 20:34
cfdfans
thanks to your help ,I will try it.
Simulate melting process of solid aluminium in liquid Titanium anirudster CFX 8 March 21, 2014 09:20
Aluminium<solid> to Aluminium <liquid> conversion in material panel zino FLUENT 3 April 25, 2011 11:04
process of an aluminium pressure casting DRW Main CFD Forum 0 October 23, 2007 03:22
Absorption coefficient for aluminium??? Thomas FLUENT 0 March 2, 2005 15:15
delete aluminium Tonmoy Roy FLUENT 1 April 21, 2004 13:35
