February 14, 2020, 10:33 |
6dof
Freddie Romero
Hello everybody.
I am new on CFD, before i has work in fluent in some simulations very easy. But now i am working in a Michell-Banki turbine simulation I have multiphase simulation with 6 DOF. Actually i know how to configure the set up of the simulation, but now i want introduce the electric charge to my simulation; that mean that in the rotor a reactive moment should back away and reduce the rotational speed. Any one who know how do it and could help me ? Thanks In advance PEACE |
February 14, 2020, 13:33 |
Torque
If the value of the reaction is known, either as a constant or as a function of known variables, then you can apply it. This needs to be applied as a moment within the UDF. Direction must be opposite to that of rotation.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 17, 2020, 14:31 |
Freddie Romero
I did it, and still the turbine increase the rotational speed. I want to know the behaviour in my turbine in accordance to the velocity inlet. If you want, I could take some pictures to show you that the rotational speed is increasing and the fluid behaviour not correspond to waited
February 17, 2020, 14:53 |
Debugging
Usually, the best way to debug something like this is to use the asymptotes, i.e., apply a very high reaction moment and then observe if the speed is controlled or not. If that does not happen, then either the moment is not being applied at the correct zone or there is something very wrong with the setup.
6dof, reactive moment |
Buoyancy and the 6DOF solver (FLUENT) | i2a | FLUENT | 16 | March 20, 2020 11:20 |
Using 6dof for 3D turbine rotation | mg.mithun | Fluent UDF and Scheme Programming | 8 | July 24, 2018 00:53 |
6DOF for spring valve motion problem | ahehuhehuh | Fluent UDF and Scheme Programming | 2 | April 18, 2018 15:39 |
Applying initial velocity to 6DOF body | amanbearpig | Fluent UDF and Scheme Programming | 0 | May 11, 2017 15:21 |
Fluent 6DOF TETRA Multibody | benjamin_ | FLUENT | 0 | November 12, 2013 04:50 |
